I have posted this already over on CN but for the benefit of the Mac people...
While I do not have any images to share from the ASI174MM yet, I can report success operating it under a parallels/Win7 VM environment with FC!
I have Mr. Edelmann to thank for this more than anything that I might have figured out. I had just about given up until I noticed that the FC2.4.08 beta release worked extremely well for the 174MM with my windoze notebook and its “slow” 7200rpm SATA HD.
I uninstalled everything related to FC/ZWO on the VM and then did a fresh install letting the driver program assign the directory that it wanted while placing FC on the root. ( Don’t know if this really helped or not- but now it WORKS!)
Before this I was unsuccessful running FC on my MAC with both TIS DFK 21 and a PG Flea3 USB. Whatever happened in the last FC beta release is GREAT!
The USB3 performance seems more than adequate with this setup based on my bench tests. This is even with splitting the quad core between OS X and the Win7pVM. The Mac’s 2GB video and 16GB ram probably helps though…
Below is a log of the performance on the Mac.
Hope I get a chance very soon to try it out on Jupiter! Looks like this camera is going to be a lot of fun!
FireCapture v2.4 beta Settings
Camera=ZWO ASI174MM
Filter=L
Profile=Jupiter
Diameter=44.11"
Magnitude=-2.49
CMI=33.7∞ CMII=201.3∞ CMIII=119.7∞ (during mid of capture)
FocalLength=10700mm
Resolution=0.11"
Filename=2015-03-05-2226_1-L-1.avi
Date=050315
Start=222611.097
Mid=222641.103
End=222711.110
Start(UT)=222611.097
Mid(UT)=222641.103
End(UT)=222711.110
Duration=60.013s
Date_format=ddMMyy
Time_format=HHmmss
LT=UT -5h
Frames captured=22321
File type=AVI
Extended AVI mode=true
Compressed AVI=false
Binning=no
ROI=512x512
ROI(Offset)=0x0
FPS (avg.)=371
Shutter=1.000ms
Gain=200
SoftwareGain=10 (off)
HighSpeed=on
Gamma=50
USBTraffic=90
AutoExposure=off
Brightness=1
Histogramm(min)=53
Histogramm(max)=176
Histogramm=69%
Noise(avg.deviation)=n/a
Limit=60 Seconds
Sensor temperature=41.1 ∞C
