Question for ZWO folks:
AM5 spec says mount can handle a 20 kg load if counterweight is used.
From a mechanical engineering point of view, what is the maximum weight that can be added to the end of the 9 inch counterweight bar without running a risk of mechanical failure, like tearing the threads out where the bar attaches to the AM5 mount body?
I'm trying to figure out how heavy a counterweight I should use at the end of the little 9-inch counterweight bar, for a relatively heavy scope.
Here's my specific case:
- Operating in alt-az mode for visual observing
- 6-inch refractor in 7-inch diameter tube in Parallax rings, one inch between saddle and tube
- scope weight with rings, dovetail bar, diagonal, finder scope, and eyepiece: 40 lb
I'm slightly under the 44 lb specified limit, so I SHOULD be able to use the AM5 without damaging it.
I could add quite a bit of weight to the little counterweight bar, but I don't want to cause failure of the threads that hold the bar to the body of the mount.
I know I don't need perfect balance between the scope and the counterweight, but any imbalance puts a side force on the RA bearing. Also, coming close to balance reduces the risk that the tripod will fall over.
If I put two 11-pound weights out at the end of the 9-inch bar, would I be in danger of breaking the bar threads? Could I go heavier than that?
Thanks!
Jeremy
Glen Head NY
