It would be great to be able to have the same level of control as nina or even be able to just use a motorised flat panel in a autorun or plan properly, without having to do a workaround like using the deepspacedad flat panel only with the "asiair cable" they have
autorun control to be able to tell when to open or close the panel in a plan, setting for closing flat panel at the end of a session just like how you can turn off the asiair/go home at the end etc
