I have a small issue that I think might be easy to fix but I'm not sure where to look. In Autorun, and perhaps Plan Mode, the ASI Air starts to capture my target after the mount goes there and focus is completed. The problem is that the first few exposures show star streaks because guiding has not settled. Once it has the remaining exposures are perfect, with guiding numbers at or below 0.6. I remember reading somewhere that you can change the settings so captures start after the mount starts to guide. Does anyone know where these setting are? Thanks in advance.
