Hello ! Would it possible to have an option to run an automated focus before doing a go-to target ?
This would enable planning a session in advance and run it without being next to the asiair to do the rough first focus in order to be able to plate solve.
Use case : I have a semi permanent setup on ly balcony, its pilar aligned and I want to plan a session to start even if I'm not home. But right now I cannot if the focus/ temperature has changed enough that the goto cannot plate-solve the stars. Being able to run an autofocus BEFORE go-to in the home position would save this and enable even more planification.
Thanks a lot
