retman the Askar part needs to go in the image train post filter (i.e., between the filter and the camera sensor)??
The Askar backfocus adjuster is the best thing that has appeared in the astrophotograhy scene in the last 10 years.  You don't find YouTube shills talk about it (not bribed enough), so it is relatively unknown.
I have them permanently installed in a couple of my OTAs that has sufficient backfocus to allow it.  And yes, you can collapse it down to 16mm (I have it adjusted to 16.7mm on one of my set ups).
It is indispensible if you have a faster OTA (e.g., f/5 or faster) that requires very precise (better than 0.1mm) backfocus.  I have them permanently fixed to my FSQ-85, Pleiades 68 and Epsilon e-130, and have used them temporarily to discover the backfocus of fast camera lenses that don't have enough backfocus to simultaneously include both the backfocus adjuster and a tilt adjuster.
Would be better if it could also adjust tilt (hint: you need to first zero out tilt before fine tuning backfocus) and if it also comes in a thinner version.  However, the M54 version of the Baader tilt adjuster (only 10-11mm backfocus needed) is coming out real soon now, and that should solve the tilts from OTAs that do not come with a built-in tilt adjusters (and can adjust backfocus of camera lenses, when a range of only 0.5mm is needed).  I also have the M68 version of the Baader on my FSQ-85.
The Askar is for backfocus adjustment, so, placed anywhere between the flattener/reducer and the sensor.  No need to restrict it to between the filter and the camera.  In fact, you probably do not want it in between a 48mm filter and a full frame camera since a filter-Askar-sensor train will likely vignette the ray from a fast scope.  The aperture of the M54 version has 46mm diameter, which is slightly larger than the clear aperture of a typical M48 ("2-inch") filter; Antlia "2-inch" filters have a clear aperture of 45mm, for example.
It also works as a very precise non-rotating helical microfocuser.
It is kind of ironic, since Askar does not even sell fast scopes that requires accurate backfocus :-).  But it is a convenient drop-in replacement for their 18mm thick camera end drawtube adapters.
