Im having the same problem over the last three nights with my new ZWO ASI 120MM, my issue is that I cannot guide using the ST4 on the camera, in PHD the DEC redline falls off at about 20 degrees, guiding via through ST4 ASCOM driver wont work on both of my lap tops, I have double checked polar alignment and have come to the conclusion either the camera, cable or EQ6 board is faulty..
My guiding via eqmod/ascom is superb, the dec and Ra are like two dolphins skimming the sea surface.. :
I really would like to use the ST4 cable directly to the EQ6 mount as its more portable for me using a little netbook..
Any help please :(
