Depending on what you received. They usually are 0.5mm, 0.19mm and 0.08mm. I have 4 cameras and each set varies slightly. In reality, close is probably as best as you are ever going to get as each of my cameras are supposed to have a sensor distance to flange of 6.5mm but my actual sensor to flange distances vary from 6.2mm, 6.4mm, 6.6mm, 6.7mm of backspacing. The sensors are not offset back all the same even with the same model. So the 17.5mm camera backspacing reference can actually be anywhere from 17.2 to 17.7mm depending on the camera. Mine are 183mc pro, 533mc pro, 585mc pro and 2600mc pro cameras. It is a royal pain when using very fast f2 telescopes.
