Is there a way in the Seestar app to turn the dual band filter option, on and off, manually.. Thx for reading.
You can do this. Before start the session you can see "Filter" on the right side of the panel. You can change it only when the session is stopped! Tap on it and when it's green, the filter is on. When it's gray, the filter is off.
