Hi' Apologies for the late post, as requested here are the details for the RGB files, incidentally..the seeing was good when I captured this series of AVI's, the capture software was Firecapture 2.4 Beta, AVI crops using Castrator, align and stacking Autostakkert II and finally wavelets, auto colour balance and histogram stretch applied in Registax v6, this was the only software which I used, no Adobe photoshop (or the likes) as there was no need to and I don't use it on my planetary images anyway, in my opinion if the seeing is good, the camera settings are correct, the collimation is correctly done, you will - or should capture good data, subsequently the result is a lot easier to come by, if I had to resort to using adobe photoshop or whatever to obtain a good image - then I simply wouldn't bother, it's very rare you obtain good seeing - more so in the Northern latitudes of the UK but when it is good - timing is critical, is the elevation optimum,wind speed minimum,dew point,lot's of factors come in to play, BUT: collimation, seeing, focus, and camera settings are paramount : )
Thanks for the kind and positive comments,
Red , Green, Blue camera settings are as follows:
Camera=ZWO ASI120MM
Filter=Red
Profile=Jupiter
Diameter=43.67"
Magnitude=-2.46
CMI=99.9° CMII=229.4° CMIII=149.2° (during mid of capture)
Filename=2015-03-10-2220_2-KJ-Red-4.avi
Date=100315
Start=222014.213
Mid=222059.215
End=222144.217
Start(UT)=222014.213
Mid(UT)=222059.215
End(UT)=222144.217
Duration=90.004s
Date_format=ddMMyy
Time_format=HHmmss
LT=UT
Frames captured=9429
File type=AVI
Extended AVI mode=true
Compressed AVI=false
ROI=512x440
FPS (avg.)=104
Shutter=9.529ms
Gain=81
Brightness=0
SoftwareGain=10 (off)
USBTraffic=64
AutoExposure=off
Gamma=0 (off)
Histogramm(min)=0
Histogramm(max)=212
Histogramm=83%
Limit=90 Seconds
Camera=ZWO ASI120MM
Filter=Green
Profile=Jupiter
Diameter=43.67"
Magnitude=-2.46
CMI=100.9° CMII=230.4° CMIII=150.2° (during mid of capture)
Filename=2015-03-10-2221_9-KJ-Green-3.avi
Date=100315
Start=222154.309
Mid=222239.313
End=222324.317
Start(UT)=222154.309
Mid(UT)=222239.313
End(UT)=222324.317
Duration=90.008s
Date_format=ddMMyy
Time_format=HHmmss
LT=UT
Frames captured=9701
File type=AVI
ROI=512x440
FPS (avg.)=107
Shutter=9.225ms
Gain=78
Brightness=0
USBTraffic=60
AutoExposure=off
Gamma=0 (off)
Histogramm(min)=0
Histogramm(max)=191
Histogramm=74%
Limit=90 Seconds
Camera=ZWO ASI120MM
Filter=Blue
Profile=Jupiter
Diameter=43.67"
Magnitude=-2.46
CMI=102.0° CMII=231.4° CMIII=151.2° (during mid of capture)
Filename=2015-03-10-2223_5-KJ-Blue-3.avi
Date=100315
Start=222334.413
Mid=222419.416
End=222504.419
Start(UT)=222334.413
Mid(UT)=222419.416
End(UT)=222504.419
Duration=90.006s
Date_format=ddMMyy
Time_format=HHmmss
LT=UT
Frames captured=5070
File type=AVI
ROI=512x440
FPS (avg.)=56
Shutter=17.75ms
Gain=67
Brightness=0
USBTraffic=70
AutoExposure=off
Gamma=0 (off)
Histogramm(min)=0
Histogramm(max)=176
Histogramm=69%
Limit=90 Seconds
