Hi,
I have 2 Autorun targets stored on USB over 2 nights each.
When attempting to use the stored images in 'image management' to GOTO target from the previous night (to maintain framing), the ASIAIR is unable to plate solve the saved images.
On a select number of them it will work(certain ones from night 1, and certain ones from night 2).
I have checked every image today by clicking 'annotate'. Some images will display the annotation and on the others , it attempts to plate solve for over a minute then eventually fails. The vast majority will not plate solve.
Any ideas how to fix this?
I've included some screenshots of back to back images of each target with both successful and failed versions.
The RA & DEC coordinates are saved on the image so I can manually input them to achieve the desired framing but I wish it would consistently solve the saved images as it takes ages to go through each and every image to see which one will work.
Many thanks
in advance.
Write a Reply...
