When connecting the S50 to a USB port on a machine running Ubuntu 24.04LTS the device says that it is connected to a computer --- true. However, it cannot be mounted into the filesystem and a continuous stream of messages appears in /var/log/syslog. The snippet given here shows the end of the log, including the messages produced after unplugging the S50.
2024-10-21T11:05:49.530925+01:00 thoth kernel: usb 1-3: new high-speed USB device number 84 using xhci_hcd
2024-10-21T11:05:49.756516+01:00 thoth kernel: usb 1-3: New USB device found, idVendor=0525, idProduct=a4a5, bcdDevice= 4.19
2024-10-21T11:05:49.756641+01:00 thoth kernel: usb 1-3: New USB device strings: Mfr=3, Product=4, SerialNumber=5
2024-10-21T11:05:49.756679+01:00 thoth kernel: usb 1-3: Product: Mass Storage Gadget
2024-10-21T11:05:49.756683+01:00 thoth kernel: usb 1-3: Manufacturer: Linux 4.19.111 with dwc3-gadget
2024-10-21T11:05:49.756685+01:00 thoth kernel: usb 1-3: SerialNumber: 33483868
2024-10-21T11:05:49.772940+01:00 thoth kernel: usb-storage 1-3:1.0: USB Mass Storage device detected
2024-10-21T11:05:49.775920+01:00 thoth kernel: usb-storage 1-3:1.0: Quirks match for vid 0525 pid a4a5: 10000
2024-10-21T11:05:49.775937+01:00 thoth kernel: scsi host9: usb-storage 1-3:1.0
2024-10-21T11:05:49.788030+01:00 thoth kernel: usb 1-3: USB disconnect, device number 84
2024-10-21T11:05:50.029932+01:00 thoth kernel: usb 1-3: new high-speed USB device number 85 using xhci_hcd
2024-10-21T11:05:50.193505+01:00 thoth kernel: usb 1-3: New USB device found, idVendor=0525, idProduct=a4a5, bcdDevice= 4.19
2024-10-21T11:05:50.193525+01:00 thoth kernel: usb 1-3: New USB device strings: Mfr=3, Product=4, SerialNumber=5
2024-10-21T11:05:50.193527+01:00 thoth kernel: usb 1-3: Product: Mass Storage Gadget
2024-10-21T11:05:50.193528+01:00 thoth kernel: usb 1-3: Manufacturer: Linux 4.19.111 with dwc3-gadget
2024-10-21T11:05:50.193530+01:00 thoth kernel: usb 1-3: SerialNumber: 33483868
2024-10-21T11:05:50.221931+01:00 thoth kernel: usb-storage 1-3:1.0: USB Mass Storage device detected
2024-10-21T11:05:50.223952+01:00 thoth kernel: usb-storage 1-3:1.0: Quirks match for vid 0525 pid a4a5: 10000
2024-10-21T11:05:50.223965+01:00 thoth kernel: scsi host9: usb-storage 1-3:1.0
2024-10-21T11:05:50.225914+01:00 thoth udisksd[1568]: Couldn't find existing drive object for device /sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-3/1-3:1.0/host9/target9:0:0/9:0:0:0/block/sdb (uevent action 'change', VPD 'pci-0000:01:00.0-usb-0:3')
2024-10-21T11:05:50.235275+01:00 thoth udisksd[1568]: Couldn't find existing drive object for device /sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-3/1-3:1.0/host9/target9:0:0/9:0:0:0/block/sdb (uevent action 'change', VPD 'pci-0000:01:00.0-usb-0:3')
2024-10-21T11:05:50.287686+01:00 thoth mtp-probe: checking bus 1, device 85: "/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-3"
2024-10-21T11:05:50.287917+01:00 thoth mtp-probe: bus: 1, device: 85 was not an MTP device
2024-10-21T11:05:50.360497+01:00 thoth mtp-probe: checking bus 1, device 85: "/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-3"
2024-10-21T11:05:50.360697+01:00 thoth mtp-probe: bus: 1, device: 85 was not an MTP device
2024-10-21T11:05:50.433352+01:00 thoth mtp-probe: checking bus 1, device 85: "/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-3"
2024-10-21T11:05:50.433554+01:00 thoth mtp-probe: bus: 1, device: 85 was not an MTP device
2024-10-21T11:05:50.534061+01:00 thoth mtp-probe: checking bus 1, device 85: "/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-3"
2024-10-21T11:05:50.534277+01:00 thoth mtp-probe: bus: 1, device: 85 was not an MTP device
2024-10-21T11:05:51.268231+01:00 thoth kernel: scsi 9:0:0:0: Direct-Access Linux File-Stor Gadget 0419 PQ: 0 ANSI: 2
2024-10-21T11:05:51.268245+01:00 thoth kernel: sd 9:0:0:0: Attached scsi generic sg2 type 0
2024-10-21T11:05:51.272918+01:00 thoth kernel: sd 9:0:0:0: Power-on or device reset occurred
2024-10-21T11:05:51.276929+01:00 thoth kernel: sd 9:0:0:0: [sdb] Media removed, stopped polling
2024-10-21T11:05:51.286956+01:00 thoth kernel: sd 9:0:0:0: [sdb] Attached SCSI removable disk
2024-10-21T11:05:51.291915+01:00 thoth kernel: usb 1-3: USB disconnect, device number 85
2024-10-21T11:05:51.549919+01:00 thoth kernel: usb 1-3: new high-speed USB device number 86 using xhci_hcd
2024-10-21T11:05:51.777937+01:00 thoth kernel: usb 1-3: New USB device found, idVendor=0525, idProduct=a4a5, bcdDevice= 4.19
2024-10-21T11:05:51.777955+01:00 thoth kernel: usb 1-3: New USB device strings: Mfr=3, Product=4, SerialNumber=5
2024-10-21T11:05:51.777957+01:00 thoth kernel: usb 1-3: Product: Mass Storage Gadget
2024-10-21T11:05:51.777958+01:00 thoth kernel: usb 1-3: Manufacturer: Linux 4.19.111 with dwc3-gadget
2024-10-21T11:05:51.777959+01:00 thoth kernel: usb 1-3: SerialNumber: 33483868
2024-10-21T11:05:51.798930+01:00 thoth kernel: usb-storage 1-3:1.0: USB Mass Storage device detected
2024-10-21T11:05:51.798948+01:00 thoth kernel: usb-storage 1-3:1.0: Quirks match for vid 0525 pid a4a5: 10000
2024-10-21T11:05:51.799909+01:00 thoth kernel: scsi host9: usb-storage 1-3:1.0
2024-10-21T11:05:51.816102+01:00 thoth (udev-worker)[363702]: sdb: Process '/usr/bin/unshare -m /usr/bin/snap auto-import --mount=/dev/sdb' failed with exit code 1.
2024-10-21T11:05:51.836999+01:00 thoth kernel: usb 1-3: USB disconnect, device number 86
2024-10-21T11:05:51.859358+01:00 thoth fwupd[12107]: 10:05:51.854 FuEngine failed to add device /sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-3/1-3:1.0/host9/target9:0:0/9:0:0:0/block/sdb: no value for VEN
2024-10-21T11:05:51.972691+01:00 thoth udisksd[1568]: Couldn't find existing drive object for device /sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-3/1-3:1.0/host9/target9:0:0/9:0:0:0/block/sdb (uevent action 'change', VPD 'pci-0000:01:00.0')
2024-10-21T11:05:51.979758+01:00 thoth udisksd[1568]: Couldn't find existing drive object for device /sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-3/1-3:1.0/host9/target9:0:0/9:0:0:0/block/sdb (uevent action 'change', VPD 'pci-0000:01:00.0')
Almost all my systems run Linux but fortunately I have a dual-boot Win10 laptop. The S50 appears as an external drive there and the files, especially the FITS file, are accessible. It is a bit of a pain to transfer files to the workstations but a kludgy work-around exists for now.
Any idea what to do to get the S50 working under Linux?
Thanks,
Paul
