I usually do wide field stuff. My seeing is usually avg.
I also have a 1200mm f4 newtonian that I pair with an asi2600 to image with. I guide it using a 200mm guidescope with an asi290mm
What calibration step pulse length, max ra and max dec settings should I use on this setup? Im using asi air so Im trying to reconfigure it to perform optimally
