Hi,
I have a permanent pier set up, and my pier is 10 metres from my warm room, if I connect the ASI camera into the 10metre active repeater cable it works perfectly, without any external power.
But if I connect it to my powered USB hub and then into the repeater cable it will not even recognise the camera, I would have though it would have been the other way round, and preferred the powered USB hub, but no, it works better with out the external power of the hub.
Problem is I need it to work with a USB hub so I can connect all my items at the same time, back to,my warm room.
Anybody else had issues with powered hubs, but have it working over a long distance like 10 metres without a powered hub??
Regards
Olly
