Hi..
I have installed the new USB 3 174MM and it runs fine with firecapture under USB 2.0. If I run it under USB 3.0 the frame rate under full mode doing 3000 frames runs at 67fps up to 700 frames and then drops to 30fps ish and is very jerky .. ie starts and stops. tried different USB traffic settings etc.
Hope someone can shed light on this.
Pete
