My best Jupiter so far.
This is made from 3 RGB AVI's 60s at around 11fps using Firecapture. The final images were 300 stacked of the 660 frames in AS'2.
I aligned the images in Maxim, which gives a purple hue to the planet. Sharpened in Registax 6, then changed the hue in PS2.
Scope 200p, Zwo ASI130mm, 3x barlow, Baader ccd filters, and a lot of luck processing.
