The Problem:
I can focus the camera through my beginner scope when viewing terrestrial objects, but I am unable to obtain good focus on lunar or planetary objects- The focuser is mid-range with Terrestrial, but can't seem to focus on more distant objects (ie, focuser is racked all the way "in" and images are still not in focus). Without the camera, images are easy to focus through the scope with usual eye pieces.
I assume I will need some attachment to shift the reflector telescope's focus into range of the ASI camera's imaging plane. It seems I need to either bring the camera closer, or shift the focus point farther out. What type of adapter would I need?
Telescope: Mead Starfinder DS-114 (4 1/2" Reflector) D=114mm F=910mm f/8
Focuser: 1.25" Meade rack/pinon focuser (replacement for original 1" Meade focuser)
Collimation: Confirmed with Orion LaserMate Deluxe II
Camera: ASI 120MC attached directly to focuser using included ZWO 1.25" adapter
Newbie from Seattle-
I'm just beginning to understand telescope and camera optics
