Hi everyone. I just acquired an ASI120MM-S. I know this is a Zwo Forum but thinking of getting an Atik-EFW2 filter wheel, most likely 36mm for my C9.25 Edge. It comes with a 2" adapter that looks like it may be able to screw into the ASI120. Not sure.
Does anyone have this combo and can share their insights? Thanks.
The sensor of ASI120MM-S is only 1/3"
so 1.25" filter should be big enough
and there is 1.25" 2" and M42 interface of ASI120MM
so every filter wheel should be compatible
Sam wrote:The sensor of ASI120MM-S is only 1/3" so 1.25" filter should be big enough and there is 1.25" 2" and M42 interface of ASI120MM so every filter wheel should be compatible
Thank you kindly, I appreciate the answer! Would 36mm filters work though? I'm looking into the future and can only get one set of filters for the time being.
Look forward to giving the ASI120 a try!
wrz0170 wrote:Sam wrote:The sensor of ASI120MM-S is only 1/3" so 1.25" filter should be big enough and there is 1.25" 2" and M42 interface of ASI120MM so every filter wheel should be compatible Thank you kindly, I appreciate the answer! Would 36mm filters work though? I'm looking into the future and can only get one set of filters for the time being. Look forward to giving the ASI120 a try!
Look up axgyl filter wheels,I have one.
