I also get the "capture failed" message when trying any long exposures with firecapture. I am running a new laptop with i5 processor, 8gb of ram and SSHD. I too have reduced the USB traffic and it makes no difference.
I have noticed that if I reduce the ROI to 640x480 or lower then that seems to cure the problem but as i'm trying to take all sky exposures that's no good.
I have tried with Sharpcap 2.5 and get a different problem. With SC, the exposure length wanders regardless what I set it at. For instance, if i set an exposure length of 8s, it will run at 8s for the first few frame captures and will then randomly change to shorter or longer exposure times, sometimes as high as 27s.
Anyone found a fix for this yet as it appears to be the camera/driver rather than capture software?
