Is it possible to remove the AR window from the ASI174MM? Can it be done simply by removing the screws on each side of the window? We're actually using this for fluorescence microscopy, which has similar challenges to planetary imaging with probably more need for the higher frame rate. Since the camera will be on top of the microscope with the sensor facing down, and screwed onto a closed lens tube, there isn't that much need for protection. Alternatively, is there information about the AR coat material, wavelength range for transmittance (or ideally a plot of either transmittance or absorbance vs wavelength?
thanks,
-Rick
