The ASI174mm will only connect to my MacBookPro late model with USB3 ports as a USB 2 device. I also experience the same on a late model Lenovo laptop with USB3.0 ports. I am plugging in directly with the supplied 2meter cable. I've used the latest drivers.
Any help with getting these computers to recognize the camera as a USB3 device would be appreciated.
Don
did you use it successfully as USB3.0 device before?
usually a host usb3.0 controller driver update can solve this problem
you can also try another usb3.0 cable
I have never gotten it to connect as USB3.0
Both computers have the latest USB3.0 updates.
No I haven't tried another USB3.0 cable.
I suggest you can try another cable
you can ask our dealer for help if you don't have another such cable
Sent camera back since it doesn't connect on several computers as a USB3.0 device.
donboy wrote:Sent camera back since it doesn't connect on several computers as a USB3.0 device. Don
no problem, how about the new camera?
