Hiho,
I had been looking forward to incorporating an ASI 120 into my setup. So, I downloaded the current version of the Linux SDK, and I am getting rather frustrated, to say the least:
I just tried building the demo examples and I stumbled over the following difficluties:
1) The make target test_gui in the demo directory references a file called main.cpp, which is in this directory
2) The Makefile has definitions for a usb library to be found in ../libusb, as seen from the demo directory. There is no such directory in the tar ball.
3) The pre-built executables you have provided in the demo/bin directory, do, of course, not work at all on a 64bit system.
In short: Could you please post a usable version?
Thanks very much in advance.
All the best,
Kai.
