I have two ZWO ASI120MM but can only select one of them. Since they have the same name, it seems applications can only show one of them and allow me to select that one only. There is no way to differentiate between the two cameras and select the second ASI120MM camera.
Is there a registry setting that can be adjusted to distinguish two cameras? Is there some other way to distinguish the two cameras?
One camera is an all-sky camera. The second camera is an imaging camera. I am unable to select the imaging camera using any application. If both are plugged in, only the all-sky is selectable.
Suggestions are appreciated.
Thanks
Bob
