pfassler wrote:No I did not adjust the white balance..I am not even sure where I can do that as I cannot find it in FC, When I capture in FC do I have to always set (check) the debayer and capture in color in settings and the temporarily disable debayer if I want to record in RAW and preview in color, or can I leave the "Debayer and capture in color " unchecked. There is not white balance adjustment in the debayering program of FC. Thanks for your help
we usually save in raw mode(debayer off) and adjust the color later
because raw data is only 1/3 size of RGB
For white balance, just click “more" near the gamma
more controls will show up
