If I select e.g. M31 via “Objects” and then tap on “Locate Target Position”, the object is displayed full screen, as if the red object frame were as large as the entire screen. However, no frame is visible, even when I zoom out. It doesn't matter which way I go into the Skyatlas and whether the Seestar is connected or not.
