Kort
If your Seestar is stuck at 0.1 degrees during the goto process, it’s because Seestar is attempting to identify its current target. This requires a sufficient number of visible stars in the field of view. Two main factors may affect this:
Ensure Seestar is pointed at an open, clear sky area with no clouds or obstructions.
Cancel the goto, and check the preview to confirm the stars are in focus.
