Latest version Seestar 2.1.0 Selected Deep Sky Stack. Chose wrong folder now when I use back in top left it exits to main screen of the app. If i go back into Deep Sky Stack it puts me back in the same folder, so I cannot use this function now.
I ended up deleting the folder I was stuck in on the seestar, then the app defaulted back to the root the next time I went into Deep Sky Stack so I could use the feature again. Not a proper resolution, but it solved my problem.
Steven I have not tried to reproduce this but good to have a workaround. If its a bug we should report it via the app.
Steven
Tap here to delect the added images and then tap 'add images' to see if works.
