Wide field DSO from Hungary,21.07.2015
lens: ASAHI Pentax Super Takumar (M42x1 screw mount) 1,4/50 on f/2,8
mount: Skywatcher Star Advanturer
72 light,24 dark frame
Camera log file:
FireCapture v2.4 Settings
Camera=ZWO ASI174MC
Filter=L
Profile=DeepSky
Filename=DeepSky_012048.zip
Date=210715
Start=012048.135
Mid=013600.957
End=015113.779
Start(UT)=232048.135
Mid(UT)=233600.957
End(UT)=235113.779
Duration=1825.644s
Date_format=ddMMyy
Time_format=HHmmss
LT=UT +1h
Frames captured=72
File type=BMP
Binning=no
Bit depth=8bit
ROI=1936x1216
ROI(Offset)=0x0
FPS (avg.)=0
Shutter=25.0s
Gain=350
SoftwareGain=10 (off)
WBlue=100
AutoExposure=off
USBTraffic=100
Gamma=50
Brightness=0
HighSpeed=off
WRed=60
Histogramm(min)=48
Histogramm(max)=255
Histogramm=100%
Noise(avg.deviation)=n/a
Limit=100 Frames
Sensor temperature=36,1 °C
