Gulyas K Thank you for using our products. Normally, Android system requires the phone or tablet version 9.0 and above, memory up to 6GB can be normal use of our Seestar, of course, the normal operation and use of our software depends on your phone or tablet can meet the operating requirements, if the low configuration can be normal operation is also possible, but may lead to some features can not be used, or with the update of some of the problems can not be solved. cannot be solved. Therefore, we recommend that you use a cell phone or tablet that meets the requirements.
