I'm wanting to direct connect my 294mm pro to the zwo 2inch 7 filter wheel. I see it can be done with other models so can I also do it with the 294? Direct connect meaning taking apart the filter wheel and screwing the back cover directly into the face of the 294.
If it's possible, are there directions posted somewhere?
And, where would I get the screws to make the connection?
Thank you.
    Thank you for this information but my question was whether I could attach (maybe I should have said "bolt") the 294 directly to the filter wheel. I have a solution to screw the 294 into the filter wheel but I'm wanting to know if I can bolt the 294 onto the filter wheel. I'm suspecting the answer is "no" but I'm looking for confirmation. thank you.
      5 days later
      dgoetz16 remove the 11mm adapter that come with the camera, and then you can directly connect to 2" efw via thread.
      Write a Reply...
