16bit usually won't needed for planetary imaging
"HighSpeed" and "hardware bin" also don't needed
but ROI usually is needed for planetary imaging
so you can save lots of harddisk space
about drop frames, this is because your harddisk is not very fast
it must drop if you capture at full resolution and in RGB24 format
so RAW8 format is good choice
debayer in AS!2 when processing
