With "planetary camera" the most optimal exposures are up to few seconds. 10 sec may be already enough. Noise will rise rapidly, while benefit from longer exposures will be much smaller.
May people just shoot few thousand 1-2 sec exposures and the process that. With alt-az stacking with derotation would have to be used.
As for C11 - DS imaging will be hard due to long focal length. But surface-bright planetary nebulae, globular clusters etc will work. F/3.3 SCT focal reducer/corrector will also work with ASI120MM small sensor.
But in general it's not something that will give spectacular results. Can be good, better the better your processing will be.
