Seestar s50 has not been able to connect to WiFi since the latest update v2.2. I’ve tried resetting the WiFi with the button underneath. I’ve reinstalled the app. I’ve turned it off and on. Nothings working.
Check what address range your WiFi network uses. ZWO have reserved the 10.0.0.0/24 network for their own use. If this is your network address, it will now refuse to connect. Your only option is to change the address of your home network.
