If you turn off the automatic horizontal calibration option, you will be able to use your Seestar again until ZWO releases updated software/firmware. You simply use the traditional bubble leveling option to ensure that your Seestar is level and it will work once more. Since turning off that option, I have captured several images successfully, in both conventional and framing/mosaic modes.
