- Edited
Hello,
I often have a problem with the GoTo in my set-up. Sometimes when I start a session the GoTo sends the scope to impossible directions (to the horizon or lower even). I am not sure what I am doing wrong.
My setup is as follows:
1) Asiair Plus
2) ZWO 2600MC Pro camera
3) a 400 mm Askar refractor scope
4) a ZWO Mini guide camera and guide scope
5) a Sky Watcher EQM 35 Pro mount (EQMOD cable for connection to Asiair Plus).
6) Asiair app on iPad (updated to the latest version 2.2 yesterday Nov 28 2024)
A new session means:
1) moving my set-up from inside the house to the garden (I am living in the Northern Hemisphere and the location is correct in the app's mount tab).
2) orienting my scope North and connecting everything
3) a mechanical polar alignment with the polar scope of the mount
4) focussing the camera and checking plate solving in the App
5) polar alignment with the Asiar and app
These 5 steps usually all go well. But after 5), when I want to point the scope to a target in the sky with the app's GoTo, it often goes completely in the wrong direction. Pointing it to some place in the sky, taking an image and then doing a plate solve and subsequent 'Sync to Mount' does sometime solve this, but not always.
Usually I get the set-up to work one way or the other by redoing the polar alignment or starting from scratch and rebooting everything. But up to now (I have the Aisiar Plus since two years now) I have not found a consistent start-up, alignment, goto and image capturing flow which takes me a predictable and reasonable time to get started.
Maybe I am doing something wrong. The manual of the Asiair Plus has only a very small section on the app and is not very clear on the different steps one should systematically do to get imaging starting.
Did/does anyone have the same problem?
Has somebody a clear flow which always works, or a link where I can find this?
Any help is welcome. Thanks in advance.
Maarten
