Hi,
tried my ASI224 with my PST for the first time yesterday. First note is that a UV block filter is absolutely required even though the PST is an Ha scope. I guess it gets warm enough that the IR is completely flooding the sensor. No Ha detail is left. I thought the Ha filter in my PST was broken and had a huge bandpass all of a sudden.
Anyway, the IR block filter solved that and solar detail returned. So then I found out that the ASI224 has terrible Newton rings. My QHY5L-IIc gives much nicer images, no Newton rings visible.
Is there any hope of resolving this with some slight tilting? I've seen suggestions of using flats but I haven't had a chance yet to try that. I have to admit I'm skeptical that the interference pattern stays in the same place enough to allow flats to remove them but I may well be wrong about that. Certainly worth a try.
I've seen posts of someone who bought a T2 tilt adapter but ended up adding his own bolt to increase the tilt. Not really fond of buying a $90 accessory only to drill new holes in it righ away.
The ASI174 doesn't have these Newton rings? Why is the 224 so susceptible?
Thanks,
Sander
