Hello,
so far I have always used the image enhancing (stacking) mode and the setting 'save each frame in enhancing'. This has worked perfectly. But now I'd rather see (and save of course) every single 10sec image live and not stack them at all. Is that also possible (how?). I only ask because the setting is called “save each frame in enhancing” and not simply “save each frame”. ? Simply set the “Live” switch to off, is that correct?
Thanks and CS Thomas
tom-dd Open “Live”, choose to save a single frame, save is able to superimpose after each frame; close “Live”, do not superimpose, will only save each frame.
No, if you don't activate Live you won't save any images.
So for now, continue using it as you always have.
