It is possible to connect, for example, Canon lenses to an ASI camera using various adapters.
In the context of a product development, the question comes up, does the tilt plate on the ZWO cameras have an approved total connection weight?
Unfortunately, I only found the drawings regarding the type of connection, but no information on the maximum weight of the lens to be connected.
As a workaround, you could attach a Y-support to the mounting rail (Vixen or similar), depending on the size of the lens, but that is of secondary importance for now.
Thank you in advance for your answers.
    5 days later
    NSQpuvZl The capity of tilt plat is enough for our 2600/6200 camera.
    I'm not understand how you want to connect it. could you please tell me more details? thanks.
    For example a Sigma 50mm f1.4 DG HSM Art Canon.
    Surely there is a weight limit or am I wrong?
    Thanks.
    NSQpuvZl I searched this lens weight online, which is close to our camera, so i think it is ok work like this, just make sure the screws on the tilte plate are fixed tightly.
    Write a Reply...
