Space Cowboy wrote:Purdyd wrote:Sam wrote:
ASCOM driver is recommended for DSO imaging
so you can use many professional DSO imaging software such like maxim-dl
Why would you use the ascom camera interface vice going directly through the .dll?
For instance, I just copied the .dll file in the ascom driver download into the firecapture directory and that appears to work fine,
I just tried copying the .dll ascom driver into FC directory and its made no difference to FC. Still can't see any high and low gain sliders like there are in the ascom platform and FC still crashes when ascom platform cam settings are activated for the asi224mc.
As far as I can tell high gain and low gain are just presets of the gain. Since you can set the gain via a slider in firecapture, I don't see why that is necessary.
I don't have the asi224mc and have not tried to set the gain by using the ascom driver and then running firecapture.
But then again, I don't see any reason to do that.
I did notice that in Maxim dl that when I access the camera properties that the zwo camera setup window has a l gain and high gain button which set the gain to 0 and 179 respectively
However I can easily do that in firecapture
So I'm not sure why using the ascom interface is the way to use the camera for deep space.
