Support@Seestar
Thanks for the reply
You don't need to be sorry, I just wanted to know whether filters are even applied when calculating the stack so that this can be taken into account during post-processing by other programs.
Using the example of gradient removal that would make repeated application in Pixinsight or Siril obsolete.
The same would also apply to an SPCC.
starnet59
You shouldn't tell me the tricks, just carry out whether you use filters like BGE, Deconv, SPCC or PCC to get the result because the result is extremely different from your own stack.
There's no question that I have to live with it, but it changes the way I process it.
