ASIAIR Mini. Have two cameras attached. ASI120 mini on guidescope (no problems ) and a Nikon zfc. ASIAIR app recognizes Nikon ZfC as a pull down option, but its not listed in the product page of compatible cameras however the z50 is and the zFC is a z50 with an added feature set. Have done all the proper pre-settings on the ZfC.... manual mode, Bulb, NR turned off, single exposure, RAW, blah blah ...also turned off save images to camera as well. Connected using 2 diff USB cables (one of them was a Nikon cable). Doesn't let me pick shutter speeds in the app, but when I change shutter speeds (or ISO) on camera, it shows value IN the app.
ASIair is powered from my CEM26 mount. Amp draw at time was UNDER 1 AMP -so not a power issue as others have suggested in the past.
Thoughts?
