After recent firmware update I have issues with focusing on planets. For example, previously I used to see Jupiter bands in 4x after reducing the brightness, now after locating the planet, in 2x and 4x mode Seestar is not able to focus on Jupiter at all, moreover, thereafter Seestar seems to stick and cant recognize the planet, if you move it to other direction and and try to return back. Turning off/on helps to locate the Jupiter again only, then the story with autofocus repeats. I've tried manual focusing, however it doesnt helps either, I still cant see any details, as I used before, only bright round spot. Meanwhile, autofocusing in stargazing mode works fine, as before.
I've seen similar reports from other users in fb, wonder whether ZWO is working on this bug and if there is any way to fix it until next firmware update?
