I guess the latest update did not clean everything from the previous version and a lot of garbage remained on your cellphone/tablet. Go to the Settings on your cellphone/tablet, then applications, look for Seestar and delete all data. Cache, settings, everything. Not the app, just the data! Now start Seestar app, go through the setup process (like when you first switched on Seestar) and hopefully everything will be working fine again. At least this "trick" helped me and solved all my problems I had.
