Hello, Sam.
Why you did not react?
"One more bug.
If you use ascom driver, pixel size in FITS header is correct - 3.75mic.
But if you use Video DS mode (in Maxim DL) - pixel size in FITS header is not correct - 5.59...microns.
So, when you use ASI120mm as a guide camera in Video DS mode - it doesn't work correct, because pixel size is not correct and calibration is not correct, so you guiding will be bad.
Sam, please, correct pixel size in video driver ASI120mm and may be other cameras too."
And Sam, will your ASCOM driver work in bin 2x2 mode for guiding? Why this mode doesn't support now?
