mtnastro In your case, you are not connected to the Internet.It is normal for the WLAN list to show that the network cannot be accessed because Seestar's WiFi is only a data transmission between the user's Seestar and the device, and it cannot access the Internet, so there will be this prompt, and it does not affect the control of Seestar.But this will not be able to use the Internet either.If you want to be able to access the Internet while connecting to Seestar's WiFi and access the Internet at the same time, you can do it in the following two ways
1 Set up mobile data on your mobile phone;
2 If you are at home, you can bridge Seestar WiFi to your home network through station mode in Seestar app, after successful bridging, you can control Seestar directly by connecting to your home network, and at the same time, you can also access the internet. Here is the link to the tutorial https://h5.seestar.com/course/79213
I hope my answer is helpful to you.
