I tried using this adapter with Meike, Samyang, and Kamlan lenses. The Meike lenses focused to infinity with an attached nebula filter. The Samuang and Kamlan lenses would not even come close to infinity focus even without an attached filter. At first, I thought I had defective lenses. However, these lenses barely reached infinity focus when attached to my Sony cameras (full frame and APS-C formats). With that in mind, I examined the ZWO adapter and decided that something was wrong with that. Sure enough! The body is too thick and creates a backfocus that is about 1.0 mm too great to achieve any kind of sharp focus on stars. I took adapter, 60 grit sandpaper, and went to work on my wife's granite counter top. After sanding off the two ridges on the underside of the adapter, I then used a much finer grade to clean up the sanded surface.
There is now no issue with achieving a sharp focus, with and without filters, on any star that I can see.
I had earlier sent this to ZWO via their web form but there has been no reply. Since I think this is a design issue with their Sony Adapter for ASI Cameras, I am puzzled as to why they appear to be ignoring what I sent them.
