How do I switch off 'Live' so that I can get back 'Continuous Shooting'? I see several statements that it can be done but not HOW to do it!
TIA
PatV
    5 days later
    PatV Connect to your Seestar and you will find it in the advanced settings.
    To enable continuous shooting, please follow the steps below:
    1. Make sure to turn on "Live" mode.
    2. Disable the "Save Single Image" option.
    This will allow continuous shooting.
      Support@Seestar i am pretty sure only step 1 is needed to enable continuous shooting. That is, you can do live stacking and still save all individual subs. Correct?
        6 days later
        KAx165v3 When "Live" is enabled, the stacked single frame will be saved. When "Live" is turned off, only the single frame will be saved, and the image will not be stacked.
        Write a Reply...
