Hi,
If I hold my ASI174MM up to the light and reflect light off the optical window it appears slightly red, whereas my ASI120MM-S has no red reflection, so it looks like my ASI174MM is fitted with an IR filter.
Should I see a slight red tint with reflected light from an ASI174MM?
The reason I ask is that when using it for Halpha, I see an uneven field, rotating the camera on the Halpha scope and the uneven field rotates with the camera, so it isn't the scope.
Thanks
Robin
