Video mode is what you use for planetary capture with the asiair. The planet is white because your exposure is way to long, for planets each exposure needs to be in the milliseconds range, not seconds. That way with a fast frame rate of capture you also increase the probability of capturing when the atmospheric seeing is still, so when using the appropriate software you'll have more good frames to stack for further detail.
