Likely some sort of interference, either local network traffic if they're all using similar WiFi channels to broadcast or materials that the WiFi is trying to transmit through.
Also if you have the V1 plus (there's 3 I believe), it's WiFi is quite rubbish. You can improve the signal by fitting an SMA extension cable between the antenna port and the antenna and moving the antenna away from your OTA. It worked for me.
